Bad column type in postgreSQL : how to not skip features ?
  • Oct 20, 2021 9:39 AM UTC
  • 72 views
user01
Hello,
I want to write features in postgreSQL. Because of a bad type of a table column some features are not written. Alert message for one of them :
210 Value of attribute 'idrlt' could not be converted to type 'int4'. Feature will be logged and skipped
I want them to be logged BUT written too (not skipped).
Is it possible ?
Thank you
  • Oct 20, 2021 10:32 AM UTC
You could use an AttributeValidator to check for invalid values, e.g. strings where there should be integers, and then perhaps try to fix those values yourself.
user01
  • Oct 20, 2021 10:43 AM UTC
Thank you, I didn't know this transformer. This is a good idea for few columns to check. The problem is that I have thousands of columns to check... but there are fews possible types so maybe I can figure out. Thanks !
