AzureBlobStorageConnector connection problems
  • Sep 3, 2020 7:29 AM UTC
  • 299 views
Hi all,
i am trying to connect with a Azure blob storage container, with the AzureBlobStorageConnector transformer in fme 2020.0.2.1.
but its not working i am getting this message:
'Server failed to authenticate the request. Make sure the value of Authorization header is formed correctly including the signature. ErrorCode: AuthenticationFailed'
And when i use the SAS url in the browser i see a xml with all the containers that are available in the blob storage.
Could someone help about this topic, please?
Hi @aarraye​ ,
Where did you get your SAS from? The screenshot you showed looks different to the SAS I generate in the Portal.
I believe in order to use SAS, you need to 'Allow blob Public Access' which you can do under Settings > Configuration in the Azure Portal.
I'm including a screenshot here of how I configured mine and you can see that it successfully listed what I have in my container:
Screen Shot 2020-09-03 at 9.40.58 AM
rob_m_esriuk
  • Feb 22, 2022 3:15 PM UTC
We are seeing this issue but only if we apply IP filtering to the SAS key, without it works fine. Were you using IP specification when generating the key
