Attribute order keeping
  • November 18, 2019
  • 177 views
Hi all,
I have a problem with extracting attributes list ordered previously with Attribute Manager.
I do it via Python Caller and exploding list which contains attributes names. It works OK but the order of these is sorted alphabetically and I need original pre-set by me order.
 def get_att_list(feature):
    n1 = feature.getAllAttributeNames()
    x=0
    for n in n1:
        print (x,n)
        feature.setAttribute('Attr_name{%d}' % x, n)
        x+=1
Generally speaking, I need to get numbers of columns in specific order to use it next in Excel vlookup formula. That is why the order is so important. Maybe there is a better way of doing it?
Forum|alt.badge.img+46
  • November 18, 2019
I don't think it's possible to get the attribute names in the same order if they've been re-arranged in the attribute manager
https://knowledge.safe.com/questions/83013/python-getallattributenames-order.html
sigtill
Forum|alt.badge.img+25
  • November 18, 2019
Perhaps you can use the Schemasetter and then reorder the list of schemas afterwards? A workaround, but still.
  • November 18, 2019
Could you tell me how to reorder schema?
