ArcGIS Pro web-app -> trigger FME script with payload selected geometries
  • Sep 21, 2022 3:25 PM UTC
  • 51 views
essb
Hi!
I just want to know if this is possible before I start to dwell deeper into it.
What I have is a web-application created in ArcGis Portal. I can select points within the app using a polygon. What I need is to be able to send only the selected points to an FME-script that should run and do an analysis on the points, all from within the web-app.
The point layer is published to ArcGis portal and its stored inside a PostGis database.
Is this possible at all?
carmijo
Forum|alt.badge.img+12
  • Sep 22, 2022 1:45 PM UTC
Hi @essb​  I believe you would need to create a list of the selected features before fme can begin working with them. maybe you can create a way for the selected features to be written to a temp file. then you could use a fme server workspace app link in the web app to trigger an fme workspace to process the features written to the temp file.
If i've provided an answer that you're happy with, please mark it as 'Best Answer'. If I didn't, please let me know if I can help further. Thanks and take care!
