API Get DATA
  • Nov 3, 2022 6:33 AM UTC
  • 31 views
siennaatsafe
Forum|alt.badge.img+12
Hi @asadmjad,
The results of the call will depend on the accept header. Accept: application/octet-stream
 returns the file. Whereas, Accept: application/json returns the metadata about the file.
If you want the file in the response body of the call you'll also want to add the query parameter dispostion=inline.
Altogether, it should look like this.
2022-11-09_14-23-09
