API Call to download a file from my shared resource folder in the FME server
  • November 4, 2022
  • 5 replies
  • 102 views
myfriendtae
Hello,
I would like to download a jpg file from my FME server and save it to my local drive with an API call.
Using FME desktop, I am not sure which transformer/writer to use, and I can't seem to find my REST API call to work. There are a few API documentations in the web, but what I tried was a GET call, but it doesn't seem to download anything.
https://<fmeserver.example.com>/fmerest/v3/resources/connections/<MY_SHARED_SOURCE>/filessys/<file_directory/filename.jpg>
I am pretty sure my auth and permission is file.
Can someone please guide me how to achieve my goal?
Kind regards,
Tae
Best answer by david_r
ccctae wrote:
Thank you for replying. I have tried the exact path, but it doesn't seem to return my file. Can you please explain a bit further?
Did you look in the API documentation? There's a concrete example of how to use the endpoint:
https://docs.safe.com/fme/html/FME_REST/apidoc/v3/#!/resources/postDownload_post_9
  • November 4, 2022
You can use the FMEServerResourceConnector transformer to e.g. download resource files from FME Server.
See https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/fmeserverresourceconnector.htm
  • November 4, 2022
myfriendtae
  • November 8, 2022
  • November 8, 2022
myfriendtae
  • November 8, 2022
Thank you very much. It seems the API point is working now. I think the header needs to be set as per the documentation. My apologies... I didn't think I can expand each section to look thoroughly...
