Hello, I have configured FME-Server for httpS. following this description https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/configuring_for_https.htm. But now is the file upload no longer working. "There was an error uploading the file"(https://docs.safe.com/fme/html/FME_Server_Documentation/WebUI/Uploading_data_files.htm) Any help is highly appreciated. Thanks.
Hello,
Could you please confirm that you modified Service URLs to Use HTTPS? Are you able to run a workspace and use other web services [data download, job submitter etc] ?
Hello,
Thank you for your reply: I can confirm that to have modified Service URLs to Use HTTPS? - But I am NOT able to run a workspace and use other web services [data download, job submitter etc]. E.g. trying to run Samples\\austindownload.fmw --> "There was an error submitting the job." --- What are the correct service URLs? Eg: Login on https://fme.test.com/fmeserver/ ==> https://fme.test.com/fmedatadownload OR https://fme.test.com/fmeserver/fmedatadownload ?
The most common reason for that error after setting up SSL is that FME Server does not trust itself, as the cert hasn't been imported into FME Server's trusted certs. Can you confirm you did this stage:
  1. Import the Keystore into FME Server's trusted certs
  2. In a command prompt, from <FMEServerDir>\\Utilities\\jre\\bin\\, use the following command to import the keystore into FME Server's trusted certs, specifying the srcstorepass argument with the password from step 1.
  3. keytool -importkeystore -noprompt -srckeystore tomcat.keystore -destkeystore "<FMEServerDir>\\Utilities\\jre\\lib\\security\\cacerts" -deststorepass changeit -srcstorepass <password>
That solved the problem.
