Adding a "Sum" row/feature to a dataset from StatisticsCalculator output?
Hi all,
Hoping you can help!
I have a dataset of assets and associated values, by date and I would like to sum each value column and add the results as a "Sum" row per date, as the image below. I am using the StatisticCalculator to generate the Sum values.
Can anyone suggest how I can take the output of the StatisticsCalculator and write the results as a row/feature?
Thanks in advance,
Mark
Forum|alt.badge.img+39
  • April 29, 2020
You can just rename the output from the summary port and combine with the original data
addsumrow.fmwt
  • April 29, 2020
addsumrow.fmwt
That is fantastic! Thank you so much for your assistance!
