Added column but e-mail function is now not working
  • Mar 23, 2021 8:11 PM UTC
  • 33 views
Have the following functional workspace that sends out e-mail notification:FMEEmailNeeded to add additional parts description to the e-mail notification.
Added that extra column in FeatureWriter:
FME2Also HTMLReportGenerator:
FME3Once I ran the workspace, it was successfully inserted into the log table:FME4However, now the e-mail notification does not work.
Anything that I missed?
Will be helpful to know how to properly add additional columns since that will be an ongoing requirement. Thanks.
daraghatsafe
Hi @fmesafejde​ is it just when adding the column that the problem arises? If you remove the column does it work again?
After adding the column can you re-add the emailer to see if that helps?
