Add space and letter to text in string
  • Oct 20, 2021 12:51 PM UTC
  • 153 views
Hi again,
I would like to change my string containing "100000,00" to "100 000,00E". In other words, adding a space and an E in the string. I can not seem to find an easy solution for this.
Thanks in advance!
Forum|alt.badge.img+63
You can use a StringReplacer with a regular expression.
Assuming you want to replace 100000 with 100 000 and 200000 with 200 000 and so on you can use (^.00) as your regular expression and \\1 as your replacement text (that's \\1 with a space behind it!)
