Add Prefix to Fanout expression in FME Desktop version 2016
  • Jan 29, 2018 1:29 PM UTC
  • 72 views
Hi @erik_jan
I'm using the Fanout expression(PLAN_NO) in FME writer to produce the DWG tiles, Fanout expression is working as expected(SD7527.dwg) . But all I need is to prefix the name 'GIS-' in the Fanout Expression, so that i need the DWG Tiles to display as GIS-SD7527.dwg . Is there any custom option in FME writer.
Any help would be appreciated.
Regards, Anil.
Best answer by ciarab
You just want to add a prefix to the expression? You can just type your required prefix in the fanout expression then add your @ value attribute afterwards
ciarab
Forum|alt.badge.img+10
  • Jan 29, 2018 1:36 PM UTC
erik_jan
Forum|alt.badge.img+26
  • Jan 29, 2018 2:06 PM UTC
And use @Value with the capital V, or it will not work.
  • Jan 29, 2018 2:56 PM UTC
Thanks @ciarab, @erik_jan adding a prefix is working.
