Accumulating attributes on a point from multiple input polygon sources
  • Apr 2, 2022 12:05 PM UTC
  • 212 views
benvk
Forum|alt.badge.img+8
I have three polygon shapefiles, they all contain a column called GUID, this column is unique, the shapefiles often overlap.
I also have a point shapefile, these points will generally fall within 1 or Many polygons.
I am trying to end up with a table similar to the one shown in my sketch.
Each point feature should have one or more GUID in it... I am sure there is a simple process to do this in FME, currently I have an overly complex looking scenario that isn't working, I am really over thinking this one.
example
Best answer by ctredinnick
You can do it with only one PoineOnAreaOverlayer. First, rename the three GUID attributes to have different names (eg pave_guid, seal_guid, segm_guid), then have the attribute accumulation on the PoineOnAreaOverlayer set to 'Merge Attributes'. That means that all attributes from area features will merge onto the points they overlap. There won't be any conflict between merging the guid attributes because they have unique names now.
If there is a chance a point will overlap two areas from the same layer, then you'll need to generate a list output on the points, and then decide from there how you want to represent that situation in your desired output.
benvk
  • Apr 2, 2022 12:13 PM UTC
In my most basic theory this is how I was setting out to achieve what I want, but I don't think it is an efficient starting point...
ctredinnick
Forum|alt.badge.img+22
  • Apr 3, 2022 8:57 PM UTC
benvk
  • Apr 3, 2022 9:00 PM UTC
Thank you, I will give that a go!
There are no overlapping features within the same layer, so the list should not be required.
Thanks again for the tip.
