Access Token Validation Failure - Invalid Audience error with SharePointOnlineConnector
  • April 12, 2023
  • 350 views
Hello!
I've been struggling with the SharePointOnlineConnector transformer for a couple days now. I have set up a web service following the official tutorial (first I've set up one for Sharepoint List, then an identical one from the Sharepoint Online template as well).
When using a Sharepoint List Reader I can successfully access the lists, but I can't access anything from the SharePoint Online Connector. I get the following error: "SharepointOnlineConnector: Error making request to https://graph.microsoft.com/v1.0/sites?$select=id,webUrl,name&search=: Access token validation failure. Invalid audience."
The app I've set up in azure has the following permissions (might be overkill, but I'm just testing for now):
Microsoft Graph (5)
Sites.Manage.All
Sites.Read.All
Sites.ReadWrite.All
User.Read
User.ReadWrite
SharePoint (7)
AllSites.Manage
AllSites.Read
AllSites.Write
MyFiles.Read
MyFiles.Write
Project.Read
Project.Write
What am I missing here?
Thanks in advance!
danilo_fme
Forum|alt.badge.img+53
  • April 17, 2023
Oi @jorge_mqn​ como você está?
Nós realizamos esta configuração para alguns clientes.
Você quer uma reunião para este Suporte?
Abraço!
JennaKAtSafe
Forum|alt.badge.img+8
Hi @jorge_mqn​ , curious how this is going for you.
If this is still an issue could you confirm that you are able to successfully make a call to your site through the Graph Explorer: https://developer.microsoft.com/en-us/graph/graph-explorer. If you are unsuccessful in this step further configurations are needed in your Azure App
