2021-12-10 10:13:48| 281.5|197.2|ERROR |Error while updating feature in the table/feature class 'DBO.DESIGN_CABLES'. The error number from ArcObjects is: '-2147207419'. The error message from ArcObjects is: {} "What's the error about ?
  • Dec 10, 2021 10:42 AM UTC
  • 61 views
Hi Team,
While synchronising the data between 2 enterprise GDB (2 separate SQL Server virtual Nodes) getting following error and terminated the FME process.
Error info:
2021-12-10 10:13:48| 281.5|197.2|ERROR |Error while updating feature in the table/feature class 'DBO.DESIGN'. The error number from ArcObjects is: '-2147207419'. The error message from ArcObjects is: {}
Note: There are not indexes, constraint rules on Both DBs.
Kindly assist us.
Regards
VIPLAW
kailinatsafe
Forum|alt.badge.img+24
Hello @viplove555​ , would you be able to share more information on the following:
  1. Are you inserting/updating/deleting? If updating or deleting, can you insert?
  2. Are your tables versioned?
  3. Are you able to successfully perform the same operation in ArcGIS?
  4. Does this occur with a specific table(s) or any table?
