GeoApps Dataset Creator
  • March 23, 2025
  • 0 replies
  • 8 views
fmelizard
Forum|alt.badge.img+21
FME Hub user wghmapgear just uploaded a new transformer to the FME Hub.
With this transformer, you can easily create a new dataset within GeoApps and add the records in it. This connection is for example useful for automated data upload from external systems or automation of repeated configurations.
Prerequisites
To use this transformer, you need to have an active GeoApps subscription and a user account with enough permissions to run the jobs. In addition, you need to first set up a web connection to GeoApps from FME. You can find the web connection in the FME Hub at https://hub.safe.com/publishers/mapgear/web-connections/geoapps.
How to use?
Add the transformer in your workspace, and configure the parameters. You need to set up two parameters: the tenant name, and the web connection to GeoApps.
Questions?
Do you need any help? Feel free to contact us at support@geoapps.nl.
Would you like to know more? Click here to find out more details!
