DGGSJSONDecoder
  • Aug 8, 2025 7:00 PM UTC
  • 0 replies
  • 35 views
fmelizard
Forum|alt.badge.img+22
FME Hub user daveatsafe just uploaded a new transformer to the FME Hub.
Decodes DGGS JSON encoded data into geometry and attributes
The DGGSJSONDecoder uses the open source dggal library to generate the cell geometry. To install the library, please follow the instructions on Installing Python Packages to FME Form to run the following install:
fme python -m pip install dggal
This library provides an interface to the following Discrete Global Grids:
GNOSIS Global Grid
Icosahedral Snyder Equal Area Hexagonal 3 (ISEA3H)
Icosahedral Snyder Equal Area Rhombic 9 (ISEA9R)
Icosahedral Vertex-oriented Great Circle Equal Area Hexagonal 3 (IVEA3H)
Icosahedral Vertex-oriented Great Circle Equal Area Rhombic 9 (IVEA9R)
Rhombic Triacontahedron Equal Area Hexagonal 3 (RTEA3H)
Rhombic Triacontahedron Equal Area Rhombic 9 (RTEA9R)
rHEALPix Global Grid
Discrete Global Grids partition the earth into a hierarchical set of polygons which can be denoted by unique identifiers, with the size of the polygon decreasing and the number of polygons incereasing as the level increases. Depending on the grid chosen, polygons can be hexagonal, rectangular or rhomboid.
Would you like to know more? Click here to find out more details!
