CGGmlTagsCreator
  • Jun 24, 2025 3:00 PM UTC
  • 0 replies
  • 24 views
fmelizard
Forum|alt.badge.img+22
FME Hub user uvmsci just uploaded a new transformer to the FME Hub.
This Transformer analyses CityGML (or any XML) file on text base.
Can be used for manipulating CityGML (adding atts, removing features, etc...).
Input:
- text lines with atts:
- text_line_data
- text_line_number
- fme_basename)
Outputs:
- TextLinesVertices: vertices with X=0, Y=text_line_number
- XmlTags: represented by lines (use SpatialFilter to filter text lines)
- GmlHeader: if present
- Values/Coords: some text lines have no XML-tag, these are mostly coords or values
- Errors:
- Bracket count not even
- Start tag without corresponding end tag
- End tag without corresponding start tag
Would you like to know more? Click here to find out more details!
