BRGMap
  • Jun 29, 2025 1:00 PM UTC
  • 0 replies
  • 56 views
fmelizard
Forum|alt.badge.img+22
FME Hub user alexbiz just uploaded a new transformer to the FME Hub.
BRGMap converts any incoming spatial features into an embeddable web map that uses an OpenStreetMap basemap. The resulting map is packaged as a BRGComponent feature containing all required HTML + CSS so it can be rendered by BetterReportGenerator (or another BRG-aware transformer such as BRGGroup). This gives you a lightweight alternative to FME’s native HTMLReportGenerator while keeping full control over look-and-feel and layout order.
Input
Any feature class that carries a valid FME geometry.
Output
Output Ports: 1
BRGComponent – Pass this feature to BetterReportGenerator or BRGGroup to embed it in your final report.
Parameter
Type / Allowed Values
Default
Description
Title
String
Map
Heading shown above the map (or in the card header).
Description
Multiline String
Optional paragraph that introduces the map section. Markdown is supported.
Map Overlay
Boolean (checkbox)
No
Unchecked – Description appears before the map.Checked – Description floats on top of the map inside a semi-transparent overlay panel.
Card Type
Enum: No Card, Static Card, Collapsable Card, Collapsed Card
No Card
Controls Bootstrap-style framing:• No Card – raw content, full width.• Static Card – framed section that is always open.• Collapsable Card – starts open, user can collapse it.• Collapsed Card – starts closed, user can expand it.
Order
Integer
0
Sort key used by BetterReportGenerator. Lower numbers appear earlier in the report.
Group By
Attribute Name (string)
When set, BRGMap will emit one BRGComponent per distinct attribute value (e.g., per city, per status). Each group gets its own Title/Description and its own map layer.
Would you like to know more? Click here to find out more details!
