BRGKeyValuesIndicator
  • Jun 30, 2025 2:00 PM UTC
  • 0 replies
  • 38 views
fmelizard
Forum|alt.badge.img+22
FME Hub user alexbiz just uploaded a new transformer to the FME Hub.
The BRGKeyValuesIndicator transformer inserts a card‑style key–value indicator into a BetterReport. It highlights one or more attribute values from the incoming features, optionally grouped and sorted, and renders the indicators as ready‑to‑embed HTML/CSS that follows the BetterReport visual language.
Ports
Port
Description
Input
Accepts any geometry or null‑geometry feature that contains the attributes you wish to display.
BRGComponent
Outputs a single feature (per group) containing the indicator’s HTML/CSS. Route this to BetterReportGenerator or BRGGroup.
Parameter
Required
Description
Key Values Attributes
Select one or more attributes to present. Each will be rendered as its own key–value tile.
Order
Integer or expression used to sort BRGComponents inside the report. Lower numbers appear first.
Group By
Attribute used to partition the input. One BRGComponent is generated per distinct value. Leave blank to treat all input as a single group.
Would you like to know more? Click here to find out more details!
