BRGImage
  • Jun 29, 2025 1:00 PM UTC
  • 0 replies
  • 33 views
fmelizard
Forum|alt.badge.img+22
FME Hub user alexbiz just uploaded a new transformer to the FME Hub.
BRGImage converts any incoming FME feature into a BRGComponent that contains the HTML + CSS needed to add an image-centric section to a Better Report Generator (or a BRGGroup). It is designed as a lightweight, highly configurable alternative to FME’s built-in HTMLReportGenerator.
2 Input & Output Ports
Port
Cardinality
Description
IN
0..∞
Any geometry or non-geometry feature you want to document.
OUT
0..∞
One feature per incoming record (or per group; see Group By). Each carries:• brg_html – the generated fragment• brg_css – styles scoped to the fragment• All original attributes (unchanged)
Tip Connect the OUT port directly to a BetterReportGenerator or to a BRGGroup chain to build multi-section reports.
3 Parameters
Parameter
Type / Options
What it does
Title
String
Heading shown above (or beside) the image section.
Description
String
Free-form text (Markdown is supported) that accompanies the image.
Image Source
URL | File
Tell the transformer where to fetch the image.
Image File / URL
String
• If Image Source = File: absolute or workspace-relative path.• If Image Source = URL: any publicly reachable URL.
Image Position
Side | Bottom
• Side: image floats left, description on the right (responsive stack on small screens).• Bottom: image sits above the description.
Card Type
No Card | Static Card | Collapsible Card | Collapsed Card
Wraps the content in an optional “card” container:• No Card: raw content, no border/shadow.• Static: always open, styled card.• Collapsible: starts open; user can toggle.• Collapsed: starts closed; user expands to view.
Order
Integer
Sorting key used by BetterReportGenerator or BRGGroup. Lower numbers appear earlier.
Group By
Attribute name
If set, incoming features sharing the same value are grouped; the first feature in each group carries the HTML for the whole group. Useful when you have many rows that refer to the same image or wish to aggregate by category.
Would you like to know more? Click here to find out more details!
