BRGChartLine
  • Jun 30, 2025 2:00 PM UTC
  • 0 replies
  • 22 views
fmelizard
Forum|alt.badge.img+22
FME Hub user alexbiz just uploaded a new transformer to the FME Hub.
BRGChartLine converts incoming FME features into an HTML/CSS (and minimal JavaScript) component that renders the selected attribute values as one or more lines on a responsive chart. The component is intended to be forwarded to BetterReportGenerator (or to a BRGGroup) where it is assembled into the final HTML report.
Typical use cases include visualising time‑series measurements, production statistics, or any ordered numeric data held in your workspace features.
Parameter
Description
Title
Text displayed as the heading of the chart section.
Description
Rich‑text block (HTML permitted) shown beneath the title. Use it to explain the data’s context.
Value Attribute Name
One or more numeric attributes to plot. A separate line is drawn for each selected attribute.
Sort Attribute
Attribute used to order the features along the X‑axis before plotting. Must be sortable (e.g. date/time or number).
X Label Attribute
Attribute whose value becomes the tick label under each point.
X Label
Text label rendered under the X‑axis.
Y Label
Text label rendered next to the Y‑axis.
Card Type
Presentation wrapper: No Card, Static Card (always open), Collapsible Card (starts open), Collapsed Card (starts closed).
Order
Integer determining where this component appears relative to other BRG components. Lower numbers appear first.
Group By
Attribute whose distinct values partition the input. One chart component is produced per group.
Would you like to know more? Click here to find out more details!
