BRGButton
  • Jun 30, 2025 2:00 PM UTC
  • 0 replies
  • 49 views
fmelizard
Forum|alt.badge.img+22
FME Hub user alexbiz just uploaded a new transformer to the FME Hub.
The BRGButton transformer creates a styled HTML button component for use in BetterReportGenerator (BRG) workflows. For every incoming feature—or for each group of features when Group By is specified—it outputs a single BRGComponent feature that contains all the HTML markup and inline CSS required to render the button in the final report.
Port
Description
Any
Accepts any feature type and schema.
Port
Description
BRGComponent
Emits one BRGComponent feature per input (or per group) representing the button.
Parameter
Type
Required
Default
Description
Button Label
Text
Text shown on the button.
URL
Text
Destination URL opened when the button is clicked.
Order
Integer
0
Determines display order inside a BRGGroup or BetterReportGenerator; lower numbers appear first.
Group By
Attribute name
(none)
If set, features sharing the same value in this attribute are aggregated into a single button component.
Would you like to know more? Click here to find out more details!
