AzureAIFoundryConnector
  • Sep 11, 2025 9:00 PM UTC
  • 0 replies
  • 114 views
fmelizard
Forum|alt.badge.img+22
FME Hub user crystalwang just uploaded a new transformer to the FME Hub.
AzureAIFoundryConnector Transformer Documentation
The AzureAIFoundryConnector is a custom FME transformer that enables integration with Azure OpenAI's Responses API. This transformer allows you to send prompts to large language models deployed in Azure AI Foundry and receive responses directly within an FME workspace. This transformer also supports a variety of tasks: text, reasoning (only available for some models), image (Vision), and file search.
Purpose
This transformer is designed for content generation, structured information extraction, summarization, reasoning, and other AI-driven tasks using Microsoft Azure’s hosted OpenAI services. It supports advanced reasoning models and file-based document processing via Azure AI's Files API.
Example Use Case
Imagine you have a dataset with a column of customer support inquiries, and you'd like to auto-generate a response or classify the sentiment. You can:
Use AttributeCreator to build a dynamic prompt string.
Pass that prompt to AzureAIFoundryConnector and choose the best model for your task.
Capture the model's response as a new attribute for downstream use.
Output Attributes
Attribute Name
Description
_response_body
The raw text response from the Azure AI Foundry model.
Response
A formatted text response from the Azure AI Foundry model
Notes
This transformer uses the Azure OpenAI Responses API (/v1/responses). It is not compatible with the chat endpoint (/v1/chat/completions) unless explicitly adapted. For Chat Completions, consider using the OpenAIChatGPTConnector instead.
Related Resources
Azure AI Services Files API
OpenAI Tokenizer Tool
Would you like to know more? Click here to find out more details!
