ArcGISEnterpriseMapServiceRebuildCache
  • Feb 16, 2024 11:00 AM UTC
  • 0 replies
  • 77 views
fmelizard
Forum|alt.badge.img+22
FME Hub user martin_ekstrand just uploaded a new transformer to the FME Hub.
Makes scheduling cache rebuilds on Map or Image services posssbile by executing a rebuild cache job on a Map service or Image service in ArcGIS Enterprise using the ArcGIS Server REST API. Then checks the job's log if the job succeeded or failed.
Runs one time per feature. You can have one feature per service name and set service name to an attribute containing your service name.
May also be run in a check job status only mode for making a 2 step automation possible for large jobs- first submit the caching job and then run another workspace at a later date to check how the job went
Would you like to know more? Click here to find out more details!
