3D Nearest Neighbor
  • July 28, 2025
  • 0 replies
  • 13 views
fmelizard
Forum|alt.badge.img+21
FME Hub user callenbanff just uploaded a new transformer to the FME Hub.
Nearest Candidate Distance Calculator
Overview
This FME custom transformer computes the 3D Euclidean distance from each input geometry in the Base dataset to its nearest neighbor in the Candidate dataset using a scipy.spatial.KDTree. The script outputs only the calculated distance as a feature attribute, suitable for proximity analysis and model validation.
Purpose
To spatially compare two point datasets (e.g., drillholes vs. model blocks) and output a scalar distance from each Base point to its closest Candidate point.
FME Workspace Context
The workflow includes the following transformers:
VertexExtractor: Converts input geometries to point representations
PythonCaller: Executes the KDTree-based distance computation
Output Ports:
Output: Features with distance result
RejectCode: Rejected features with error metadata
Input Requirements
Two point geometry datasets:
Port
Description
Base
Input geometry features to be tested
Candidate
Reference geometry features
Each geometry is converted into XYZ coordinate attributes:
Attribute
Source
Description
X_Base
Base
Extracted X from geometry
Y_Base
Base
Extracted Y from geometry
Z_Base
Base
Extracted Z from geometry
X_Candidate
Candidate
Y_Candidate
Candidate
Z_Candidate
Candidate
Type
Assigned
Either "Base" or "Candidate"
Output
Main Output (Output port)
Attribute
Description
Easting
X coordinate from original Base point
Northing
Y coordinate from original Base point
Elevation
Z coordinate from original Base point
Distance
3D Euclidean distance to nearest Candidate
Rejection Output (RejectCode port)
Rejected features are annotated with:
Attribute
Description
fme_rejection_code
Reason code for rejection
fme_rejection_message
Descriptive rejection message
Methodology
Geometry Conversion
Input geometries are processed into XYZ attributes via VertexExtractor and AttributeManager.
Classification
Features are tagged with "Base" or "Candidate" using custom attribute assignment.
Feature Consolidation
FeatureJoiner merges all features for global analysis in the PythonCaller.
Distance Calculation
KDTree (from scipy.spatial) computes nearest neighbor distances in 3D space.
Output and Cleanup
Distance results are passed to Output. Invalid or empty input arrays are flagged and routed to RejectCode.
Dependencies
Python packages required within the FME environment:
numpy
pandas
scipy
fme, fmeobjects
References
SciPy KDTree Documentation
FME PythonCaller Documentation
Would you like to know more? Click here to find out more details!
