Open a file on FME_SHARED_RESOURCE_DATA Directory with pythonCaller
  • November 11, 2021
  • 9 replies
  • 133 views
geobiker
Hello,
I want to open a file with the PythonCaller stored on the [FME_SHARERESOURCE_DATA] directory.
The python enviroment can access the directory and the script end with an exception:
TypeError: expected str, bytes or os.PathLike object, not NoneType
Is it possible to map the FME_SHARED_RESOURCE_DATA Directory in the python script?
Kind regards
Stefan
virtualcitymatt
Forum|alt.badge.img+35
Not sure it this really helps you, but I have found adding a ParameterFetcher before the a python caller can make things a little easier to work with. Get the [FME_SHARERESOURCE_DATA]  as an attribute.
Keep in mind that When working in Desktop the [FME_SHARERESOURCE_DATA]  will be empty because this us only used in FME Server.
geobiker
  • November 11, 2021
My Problem is related to the server not to desktop. In the workbench i can read the directory on [FME_SHARERESOURCE_DATA] with the "Directory and File Pathnames Reader" successfully and then I can analyse the lasted filename as a attribut. But then the access the file in the python script is not possible.
  • November 11, 2021
You can access the parameter value in Python like this:
fmeserver_data = fme.macroValues.get('FME_SHAREDRESOURCE_DATA')
if fmeserver_data:
    # Note that FME_SHAREDRESOURCE_DATA is usually undefined on Desktop
    with open(fmeserver_data+'/filename.txt''r'as f:
        contents = f.readlines()
geobiker
  • November 11, 2021
thanks.
Why it is not possible to use the path_unix attribut directly?
#  attribute from the Directory and File Pathnames Reader
feature.getAttribute('path_unix'
  • November 11, 2021
geobiker wrote:
thanks.
Is it not? That is surprising. What is the value of 'path_unix'? What is the error message?
geobiker
  • November 11, 2021
            json_file_new = feature.getAttribute('path_unix')
            logger.logMessageString("FME_SHAREDRESOURCE_DATA: %s"%(shared_resource_data_path))
            logger.logMessageString("PATH_UNIX: %s"%(json_file_new))
            json_data_new = codecs.open(json_file_new,encoding="UTF-8",mode="r")
LOG-FILE
279	2021-11-11 12:18:56 | FME_SHAREDRESOURCE_DATA: /data/fmeserver/resources/data/
280	2021-11-11 12:18:56 | PATH_UNIX: /data/fmeserver/resources/data/xxx/xxxx/xxxxxx/xxxxxxxx/yyyyyyyyy_20211111.json
281	2021-11-11 12:18:57 | Python Exception <TypeError>: expected str, bytes or os.PathLike object, not NoneType
282	2021-11-11 12:18:57 | Traceback (most recent call last):
283	2021-11-11 12:18:57 | File "<string>", line 37, in input
284	2021-11-11 12:18:57 | File "/usr/lib/python3.6/codecs.py", line 897, in open
285	2021-11-11 12:18:57 | file = builtins.open(filename, mode, buffering)
286	2021-11-11 12:18:57 | TypeError: expected str, bytes or os.PathLike object, not NoneType
287	2021-11-11 12:18:57 |
288	2021-11-11 12:18:57 | Error encountered while calling method `input'
289	2021-11-11 12:18:57 | PythonCaller (PythonFactory): PythonFactory failed to process feature
FME Version
FME Server 2020.2.1
Build 20806 - linux-x64
  • November 11, 2021
LOG-FILE
FME Version
FME Server 2020.2.1
Weird. What happens if you hard-code the filename into the call to codecs.open()? Does that work?
Can you also try to log the following to check what the object type of json_file_new is:
logger.logMessageString("type of json_file_new: %s" % type(json_file_new))
geobiker
  • November 11, 2021
Hi david,
i found the problem. The second attribut for the second file was not set successfully. Now the PythonCaller works fine.
Thanks for your help
Kind regards
Stefan
  • November 11, 2021
geobiker wrote:
Hi david,
Kind regards
Stefan
Thanks, glad to hear you got it working.
