Open a file on FME_SHARED_RESOURCE_DATA Directory with pythonCaller
  • Nov 11, 2021 7:11 AM UTC
  • 9 replies
  • 252 views
geobiker
Forum|alt.badge.img+4
Hello,
I want to open a file with the PythonCaller stored on the [FME_SHARERESOURCE_DATA] directory.
The python enviroment can access the directory and the script end with an exception:
TypeError: expected str, bytes or os.PathLike object, not NoneType
Is it possible to map the FME_SHARED_RESOURCE_DATA Directory in the python script?
Kind regards
Stefan
itsmatt
Forum|alt.badge.img+48
  • Nov 11, 2021 8:37 AM UTC
Not sure it this really helps you, but I have found adding a ParameterFetcher before the a python caller can make things a little easier to work with. Get the [FME_SHARERESOURCE_DATA]  as an attribute.
Keep in mind that When working in Desktop the [FME_SHARERESOURCE_DATA]  will be empty because this us only used in FME Server.
geobiker
  • Nov 11, 2021 8:54 AM UTC
My Problem is related to the server not to desktop. In the workbench i can read the directory on [FME_SHARERESOURCE_DATA] with the "Directory and File Pathnames Reader" successfully and then I can analyse the lasted filename as a attribut. But then the access the file in the python script is not possible.
  • Nov 11, 2021 10:20 AM UTC
You can access the parameter value in Python like this:
fmeserver_data = fme.macroValues.get('FME_SHAREDRESOURCE_DATA')
if fmeserver_data:
    # Note that FME_SHAREDRESOURCE_DATA is usually undefined on Desktop
    with open(fmeserver_data+'/filename.txt', 'r') as f:
        contents = f.readlines()
geobiker
  • Nov 11, 2021 10:28 AM UTC
thanks.
Why it is not possible to use the path_unix attribut directly?
#  attribute from the Directory and File Pathnames Reader
feature.getAttribute('path_unix')
  • Nov 11, 2021 10:35 AM UTC
thanks.
Is it not? That is surprising. What is the value of 'path_unix'? What is the error message?
geobiker
  • Nov 11, 2021 11:21 AM UTC
            json_file_new = feature.getAttribute('path_unix')
            logger.logMessageString("FME_SHAREDRESOURCE_DATA: %s"%(shared_resource_data_path))
            logger.logMessageString("PATH_UNIX: %s"%(json_file_new))
            json_data_new = codecs.open(json_file_new,encoding="UTF-8",mode="r")
LOG-FILE
279	2021-11-11 12:18:56 | FME_SHAREDRESOURCE_DATA: /data/fmeserver/resources/data/
280 2021-11-11 12:18:56 | PATH_UNIX: /data/fmeserver/resources/data/xxx/xxxx/xxxxxx/xxxxxxxx/yyyyyyyyy_20211111.json
281 2021-11-11 12:18:57 | Python Exception <TypeError>: expected str, bytes or os.PathLike object, not NoneType
282 2021-11-11 12:18:57 | Traceback (most recent call last):
283 2021-11-11 12:18:57 | File "<string>", line 37, in input
284 2021-11-11 12:18:57 | File "/usr/lib/python3.6/codecs.py", line 897, in open
285 2021-11-11 12:18:57 | file = builtins.open(filename, mode, buffering)
286 2021-11-11 12:18:57 | TypeError: expected str, bytes or os.PathLike object, not NoneType
287 2021-11-11 12:18:57 |
288 2021-11-11 12:18:57 | Error encountered while calling method `input'
289 2021-11-11 12:18:57 | PythonCaller (PythonFactory): PythonFactory failed to process feature
FME Version
FME Server 2020.2.1
Build 20806 - linux-x64
  • Nov 11, 2021 12:23 PM UTC
LOG-FILE
FME Version
FME Server 2020.2.1
Weird. What happens if you hard-code the filename into the call to codecs.open()? Does that work?
Can you also try to log the following to check what the object type of json_file_new is:
logger.logMessageString("type of json_file_new: %s" % type(json_file_new))
geobiker
  • Nov 11, 2021 2:47 PM UTC
Hi david,
i found the problem. The second attribut for the second file was not set successfully. Now the PythonCaller works fine.
Thanks for your help
Kind regards
Stefan
  • Nov 11, 2021 2:53 PM UTC
Hi david,
Kind regards
Stefan
Thanks, glad to hear you got it working.
