How to add quotes around parameters values
  • Sep 30, 2022 11:58 AM UTC
  • 6 replies
  • 444 views
so_much_more
I want to run a SQL before a writer to a postgis database.
I am using parameters to dynamically run the SQL queries. Since SQL is case sensitive and my tables include case characters I need to put quotations around my table names. But putting quotes around my statement make it a string. I just want to add quotes the parameters value.
select * from "$(schema)"."(fme_feature_type)"
Desired result
select * from "MySchema"."A_Table"
Is there a way to escape the quotes somehow to just add quotes around the paramaneter value.
Best answer by nielsgerrits
The published parameter should work this way. If you want the fme_feature_type part dynamic, you need to use.
select * from "$(schema)"."@Value(fme_feature_type)"
nielsgerrits
Forum|alt.badge.img+67
  • Sep 30, 2022 12:18 PM UTC
so_much_more
  • Sep 30, 2022 12:38 PM UTC
I have tried that too. But FME execute it as
Error executing SQL command ('Select * from MySchema.MyTable'):
'ERROR:  relation "MySchema.MyTable" does not exist'
I need the quotes to be part of the statement
Select * from "MySchema"."MyTable"
nielsgerrits
Does it work when you use an AttributeCreator to create the code and put the attributevalue in the SQLCreator?
dustin
Forum|alt.badge.img+36
  • Sep 30, 2022 12:48 PM UTC
I suppose you could create the SQL query in an AttributeCreator as it is now. Then in a StringReplacer after that, replace . with "."
Try:
Be aware that the name of the published parameter is case sensitive.
so_much_more
  • Sep 30, 2022 12:58 PM UTC
In closer inspection I think it actually work to do what you originally suggested. Not sure where i looked wrong. But it seem to be solved. It just look in the SQL dialog that the parameter will be evaluated as a string. Great! Thank you
