FME Flow Hosted - Connect to my internal network
  • Jul 18, 2025 1:44 PM UTC
  • 124 views
philippeb
Forum|alt.badge.img+23
We want to install FME Flow Hosted and would like to access to our internal network, so users can Read and Write files from the several disks.
How can we do that?
Thanks!
NickAtSafe
Forum|alt.badge.img+14
  • Jul 18, 2025 2:58 PM UTC
Hi ​@philippeb!
Unless the data is publicly exposed (ie you can easily access it internally already), the only way to accomplish what you’re looking for, while still using Flow Hosted, would be to use a Remote Engine. This essentially would allow you to install an FME Engine inside your internal environment, and have it controlled by your Flow Hosted instance.
The only other alternative would be to host FME Flow on your own infrastructure - then it’ll have access to whatever internal resources you’re looking for.
philippeb
  • Jul 18, 2025 4:39 PM UTC
Can I use many remote engines on different environment (Azure) from Flow Hosted?
NickAtSafe
  • Jul 18, 2025 4:49 PM UTC
It should be okay to run them anywhere - as long as you have access to the server to install it, it meets any specifications (o/s, etc.), and it can communicate with the outside internet (no firewalls, etc.). Here’s some more details here about how to work with it.
