Connection to Flow
  • May 30, 2024 4:24 PM UTC
  • 130 views
oumar
Forum|alt.badge.img+3
Hi All,
I am getting this error when i open FME Workbench and I am not sure what to do at this point this was working for me. I am no longer able to connect to my FME Flow established connection.
2024-05-30 11:14:36|   |   |WARN |SQL Query UPDATE fme_nc_namedconnections set connectiontype = connectiontype WHERE fme_nc_namedconnections.ncid = ? failed. Error: attempt to write a readonly database
matt.m-at-safe
Forum|alt.badge.img+14
Hi @oumar, is your workspace perhaps trying to access a shared connection that you no longer have access to? Or maybe the shared connection location has moved? This article explains shared connections in FME Form (this is only applicable for FME Form 2023 and earlier, since connection storage changed in 2024).
https://support.safe.com/hc/en-us/articles/25407698305037-Making-Database-and-Web-Connections-Public
I recommend submitting a case if you’re still having issues: https://support.safe.com/hc/en-us/p/Support
