Hi: I'm new to this forum and just found out about FME. I was curious if there was a way to use FME to create a workflow that allows you to update changes to a .mxd in ArcMap then have the changes update to a .dwg in AutoCAD. Or at the very least make the process of transferring over pt/line shapefiles easier to AutoCAD for .dwgs that need regular update maintenance. In particular I'm thinking of a city/municipality utility map where changes are made on the ArcMap side then translated to the AutoCAD side (or vice versa as many engineering firms tend to create construction/as-built drawings with AutoCAD). Any thoughts?
Is there a way to make updates in ArcMap sync with AutoCAD (or at least make that update process quicker?)
