SharePoint Issues
  • Apr 16, 2024 4:24 PM UTC
  • 223 views
adrian_farrell
Hi
Could anyone help please? I have created two connections to Microsoft SharePoint, one for SharePoingOnlineConnector and one for SharePoint List Reader/Writer in FME Form.
When i use either after uploading to FME Flow i get this error from Flow when running a published Flow App but it seems to work when running directly from the Flow UI
SharepointOnlineConnector: Connection 'xx SharePoint Files' does not exist. Check connection parameter and connection definitions in FME options and try again
I have gone into the group settings and granted full control to every user group that can use the Flow App, we are using AD authentication and that appears to be working fine.
If anyone can assist i would be very grateful
Thanks
Adrian
Best answer by siennaatsafe
Hi @adrian_farrell,
I think you may have an issue with the permissions on the FME Flow App, I think the App itself may not have permissions to access that connection.
Flow apps use API tokens, these tokens need permissions to access the web connection.
Could you try following the instructions here under User is the Token Owner ? And confirm that the API token for your app has permissions to your sharepoint connection.
Let me know how that’s the issue! Or if you need additional help.
siennaatsafe
Forum|alt.badge.img+12
  • Apr 17, 2024 11:04 PM UTC
Hi @adrian_farrell,
adrian_farrell
Thank you so much :)
