HTTP Error wtih backupConfiguration.fmw/JobHistoryStatisticsGathering.fmw in FMEFlow 2024.2
  • May 20, 2025 9:49 PM UTC
  • 208 views
agelfert
Forum|alt.badge.img+8
Getting an error with the default (OOTB) schedules/workspaces for :
  • backupConfiguration.fmw
  • JobHistoryStatisticsGathering.fmw
Both times it’s an SSL error with the HTTPCallers in those workspaces. Looks to me like they’re calling a URL based on the Windows machine name provided (gathered?) during installation.
This was not an upgrade but fresh install so I think this thread about the API version does not apply. It’s definitely calling V3.
However, after the initial install, I have switched to HTTPS and added a DNS name with a valid SSL cert. All my services - Data Download, Data Streaming, Job Submitter etc - are working fine with this new name/URL.
But the HTTPCaller still uses the FME_SERVER_WEB_URL
(FME_SERVER_WEB_URL)/fmerest/v3/migration/backup/download
which I think comes from
fmeFlowConfig
Did I miss a step when setting up HTTPS and should I have switched this entry? If not, is it safe to just put the full DNS name for my FME Server instance in the fmeFlowConfig ?
Not a huge issue with the backups, I don’t rely on them. But I’d like to get the statistics going.
Thanks
skyleratsafe
Forum|alt.badge.img+9
Hi ​@agelfert,
For HTTPS configuration, both FME_SERVER_WEB_URL and Service URLs need to be updated. This article provides detailed instructions on HTTPS configuration with different types of certificates used. https://support.safe.com/hc/en-us/articles/25407415461517-Configuring-FME-Flow-for-HTTPS
For example, if you are using a CRT or CER certificate, make sure step 11 and step 13 were configured correctly according to this article. https://support.safe.com/hc/en-us/articles/25407506647181-Configuring-FME-Flow-for-HTTPS-Using-a-CRT-CER-Certificate
If the issue still exists, please feel free to submit a support ticket and share the tomcat log folder located in Resources > Logs. Also, the log files show the specific SSL error message would be helpful.
I hope that helps.
Skyler
agelfert
  • May 21, 2025 6:06 PM UTC
Thanks, Skyler - I will look at those pages and give it a try.
alexbiz
Forum|alt.badge.img+35
  • May 22, 2025 7:32 AM UTC
“Looks to me like they’re calling a URL based on the Windows machine name provided (gathered?) during installation.”
That seems like an FME_SERVER_WEB_URL misconfiguration for sure.
Another article that's a "must bookmark" for those kinds of deployments:
https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Changing-Web-App-Server-Host-Name-Port.htm#:~:text=Open%20the%20propertiesFile.,Restart%20FME%20Flow.
