FME Server - health check fails using API V4
  • Oct 8, 2024 12:12 PM UTC
  • 124 views
mohameddridi
Observer
Hello,
I’m actually running an instance of FME Server deployed using Safe Software’s Helm chart.
The core component image version is 2024.1, and the HTTP readiness probe path is the following:
/fmeapiv4/healthcheck/readiness
The result of a get request is the following:
"status": "notReady",
"message": "One or more essential processes are unavailable.",
"components": [
"component": "notifier",
"status": "up"
"component": "connections",
"status": "up"
"component": "queue",
"status": "up"
"component": "resources",
"status": "up"
"component": "core",
"status": "up"
"component": "cleanup",
"status": "up"
"component": "configuration",
"status": "up"
"component": "relayer",
"status": "up"
"component": "scheduler",
"status": "up"
"initializationTasks": [
"task": "installDefaultContent",
"status": "failure"
The problem seems to be with initialization tasks.
Do you have a pointer to where to look in order to fix this ?
Thanks
damiobasa
Forum|alt.badge.img+3
  • Oct 11, 2024 8:05 PM UTC
Hello
What deployment type are you using to install FME? Also if using Kubernetes can you run describe on the core container and post what information you see there? in the meantime, It could also be helpful to restart the services
