FME server 2020.2 failing with - "Unable to perform any licensing related tasks. This 64-bit version of FME requires 64-bit Background Geoprocessing, ArcGIS Pro or ArcGIS Server"
  • March 12, 2025
  • 5 replies
  • 72 views
pragathjobs
Forum|alt.badge.img+3
FME server 2020.2 failing with - "Unable to perform any licensing related tasks. This 64-bit version of FME requires 64-bit Background Geoprocessing, ArcGIS Pro or ArcGIS Server". There is already ArcGIS pro installed on same machine and the version of ArcGIS Pro is 2.6. Is ArcGIS server required for this?
crutledge
Forum|alt.badge.img+44
  • March 12, 2025
Hi ​@pragathjobs
There maybe a difference a user install and machine install for Pro.
Solved: Install ArcGIS Pro with a 32 bit Desktop license - Esri Community
Also check notes on compatibility. Notes on FME and Esri Versions and Compatibility – FME Support Center
Also make sure you have “logged into” ArcGIS Pro. I have found that if the license has not been activated by a named user we get licensing issues.
Hopefully that helps and Good Luck!
c.
pragathjobs
  • March 12, 2025
Thanks @crutledge
I tried with logging on into ArcGIS Pro and still it dint work. The pro version is 2.6 as per the document you shared its compatible with FME 2020.2.
crutledge
  • March 12, 2025
Hmmm. Could it be a licensing issue between Basic, Standard, Advanced for ESRI? I don’t know if FME could call a function that would require a higher level license in Pro. I imagine everything would work with a Basic license. Unsure on that.
Good Luck!
pragathjobs
  • March 12, 2025
Hi ​@crutledge I already have an Advanced ArcGIS Pro License. I am confused if ArcServer has to be configured on the same machine.
crutledge
  • March 12, 2025
Hi ​@pragathjobs
I think I am out of ideas on this one. Only other thing I came across that might help is FME Server not able to access ArcPro | Community
Ah the joys of troubleshooting….it only needs to work once :D
Good luck!
