De-install custom python (The User-specified library ...python37.dll could not be loaded)
  • May 29, 2024
  • 107 views
vki
Forum|alt.badge.img+7
We used to need custom python on FME-Server. I’m no system administrator, but I had found out how to install it (Using Python with FME Flow (safe.com)).
Now we updated to FMEFlow 2024 and we don’t need custom python anymore, so I didn’t install it. but obviously it is still registered somewhere that we used to need a different python.dll, for I get the warning “The User-specified library ...python37.dll could not be loaded”.
How can I reset everything to default-settings? I tried it with this:
<FMEFlowDir>Server/fme/fme.exe APPLY_SETTINGS SYSTEM "Python/Use Custom Python 64" false
and restartet the FMEServer-services, but the warning remains in the log.
Thanks, Vera
Update:
I ran this command as well to reset to the standard python.dll:
<FMEFlowDir>Server/fme/fme.exe APPLY_SETTINGS SYSTEM "Python/Python Interpreter 64" "C:\Program Files\FMEFlow\Server\fme\fmepython312\python312.dll"
Now I get this warning:
The PYTHONHOME `...' for the user-specified Python interpreter set through FME Options or a PYTHONHOME environment variable does not exist. The user-specified Python interpreter will be used without PYTHONHOME defined, which may cause undefined behavior.
There’s a third command in the above instruction, but I don’t want to set a Custom Python Home, but to get rid of any custom python settings...
<FMEFlowDir>Server/fme/fme.exe APPLY_SETTINGS SYSTEM "Python/Custom Python Home 64" c:/<path_to_python_home>
lifalin2016
Forum|alt.badge.img+40
  • July 12, 2024
The environment variable PYTHONHOME is always present with Python, not just for custom installations.
Try and recreate it.
