Hi, we are silent installing FME Flow for the first time. We used to install FME Server using a silent install script, which uses the next installation properties:
FMESERVERHOSTNAME
INSTALLDIR
FMESERVERSHAREDDATA
PGDATA
WEBSERVERHOSTNAME
SERVLETPORT
DATABASEPASSWORD
In the new FME Flow silent install instructions, a different set of installation properties is used. I think the properties above compare to
COREHOSTNAME (changed)
INSTALLDIR (unchanged)
FMEFLOWSHAREDDATA (changed)
PGDATA (unchanged)
EXTERNALHOSTNAME (changed)
SERVLETPORT (unchanged)
DATABASEPASSWORD (unchanged).
My questions:
- Can this be confirmed?
- Would it be possible to get a link to the location where this is documented?
