CI/CD Pipeline for FME Flow Overwrites Deployment Parameters – Bug or Misconfiguration?
  • Nov 13, 2025 2:33 PM UTC
  • 147 views
peterhavik
Forum|alt.badge.img+4
We are implementing a CI/CD pipeline for FME Flow using an Azure YAML pipeline. When exporting an FME project from DEV with deployment parameters enabled under Advanced Options, those parameters overwrite the values in ACC and PRD during deployment. If the same project is imported manually, this issue does not occur.
  • Is this a known bug in the FME Flow API?
  • Or is there a recommended way to prevent deployment parameters from being overwritten during automated deployments?
Additional details:
  • If all advanced options are manually unchecked, deployments work as expected.
  • The token used for the pipeline requires full permissions (fmesuperuser); otherwise, roles cannot be deployed. Restricting permissions or deployment parameter rights results in nothing being deployed.
FME Flow version we have is 2024.1.2
Any insights or best practices would be appreciated!
Best answer by evieatsafe
Thanks for your question ​@peterhavik! Looks like you submitted a support ticket about this as well. For anyone else coming across this in the future, I will summarize the resolution below.
The recommended solution is to migrate to the FME Flow REST v4 API. The v4 API handles this correctly by automatically excluding deployment parameters during import. The v3 endpoint has entered its deprecation phase as of FME Flow 2025.1 and is planned for removal in 2026.1, so upgrading is the path forward regardless.
A couple of things to be aware of when moving to v4:
  • The older beta endpoints (/fmeapiv4/migrations/imports/upload?skipPreview=true and /fmeapiv4/migrations/imports/$id/run) have been removed from the stable v4 release and will return a 404. Use the stable v4 endpoints instead.
  • Documentation available here: https://docs.safe.com/fme/html/fmeapiv4/docs/index.html
In the meantime, if you need a short-term workaround on v3, you can uncheck the "Include Deployment Parameters" option during manual export. This method is prone to human error which is why migrating to v4 is a better long-term fix.
Happy FMEing!
evieatsafe
Forum|alt.badge.img+28
  • May 5, 2026 11:15 PM UTC
Happy FMEing!
