[CI/CD] FME Flow Api V4 and Ansible : An issue to upload file
  • Nov 19, 2025 12:47 PM UTC
  • 0 replies
  • 81 views
christelle
Forum|alt.badge.img+7
Hello,
I want just to share a issue and the solution, I encountered with my CD pipeline.
  • The FME Flow : 2024.2.3
  • Ansible version below 2.19
The need : upload file in a ressource connection or upload fsproject file. But for specific reason I had to use Flow api V4.
FME Flow API
In Api V3, we can use the upload file in the body with these resquest
post /resources/connections/{resource}/filesys/{ path }
It’s support to set the file in the body for the upload a single file or the multipart form data. Both are available.
In api V4 the request to upload a file is :
Post /resources/connections/{connection}/upload
And for upload fsproject for import
Post /migrations/imports/upload
Both in api V4 support only the multipart form data.
Ansible
The module uri support the mulitpart form data that only from 2.19. And I have not the hand on the devops tool.
Solution
I use a curl command line with FME flow api v4.
Personnaly, I prefere the versatility of api v3. It’s sad that the api v4 reduce the possibility.
