Best EC2 instance type for FME
  • Mar 9, 2025 8:05 AM UTC
  • 175 views
9val
Hi all,
Could you please share your experience on what types of AWS EC2 instances you use for FME Flow and FME Form. I wonder if the M5 instance type is recommended since it is used for FME Flow Hosted. We mostly use “t3.large”.
I understand that the choice depends on server load etc., but I would like to know the best practices.
Thanks!
Best answer by peterhearns
I’ve been experimenting for several months now for this using Form and Flow.  The data set that I am using has about 25 million records per day and I am processing 14 days worth of it to insert into our database. The data insert ends up being less than 10M records. I started using an m5.xlarge but was working on extremely large datasets and noticed that the memory usage was maxing out in Form and Flow was taking a very long time.
Using a memory optimized instance was the best solution for me.  For Form I started using an r6i.2xlarge (64GB memory) where I no longer get memory issues. For Flow I was using an r6i.xlarge (32 GB memory).  In Flow the process was taking a little over 24 hours.  It uses 100% cpu and doesn’t utilize all of the 32GB of memory in this case.  We decided to try the r7i.xlarge which is essentially the same but has a newer generation CPU and run the update once again.  This time the process took 19.5 hours.  There was a ~20% processing speed increase.
While each use might have it’s own needs, the super sized datasets definitely need the memory component. I definitely recommend the Memory Optimized instance types since this seemed to be my largest bottleneck.
hkingsbury
Forum|alt.badge.img+73
  • Mar 9, 2025 7:31 PM UTC
For training we use t3(a).xlarge. Its sufficient for that purpose, but I would want a more powerful instance for large data processing.
One thing to also consider is the iops of your storage, the higher the better (faster)
Forum|alt.badge.img+63
It really depends on what you want to do with it. Higher specs means shorter processing times (more or less, there’s a lot of factors involved of course) but it’s up to you to decide whether the extra cost is worth it.
peterhearns
Forum|alt.badge.img+8
  • Aug 19, 2025 12:26 PM UTC
