backupConfiguration Workspace does not use the datestamped attribute in Flow 2025.2.1
  • Dec 23, 2025 12:33 AM UTC
  • 6 replies
  • 238 views
mgg_beca
Forum|alt.badge.img+20
Hi there,
Just finished a fresh install of FME Flow 2025.2.1.
I was configuring the backups and noticed that the output files were not getting a timestamp.
Looking at the httpcallers they both submit using the non-timestamped attribute:
If Append Date is No:
If Append Date is yes:
What it should be:
Thanks,
Marc
Best answer by zoe.forbes
Hi ​@rudy_v,
A fix has been implemented and is currently planned to be shipped with 2026.1 (although this is not guaranteed). I’ve attached the updated workspace for 2025.2.3 for you to use in the meantime.
Please let me know if you have any questions about this!
skyleratsafe
Forum|alt.badge.img+9
Hi ​@mgg_beca,
I was wondering what FME Form version you are using. Is it the same version as FME Flow?
Based on the screenshots, it appears that the actual value of packagePath is not automatically updated when you set 'append date' to 'yes'.
However, I could see the _timestamp attribute under the FME Feature Attributes. I would recommend concatenating the original path and timestamp and checking if that works.
Cheers,
Skyler
mgg_beca
  • Jan 11, 2026 10:51 PM UTC
Hi ​@mgg_beca,
Cheers,
Skyler
Yes I have also install the latest version of FME Form, so they match.
I can also see the timestamp attribute, and the concatenated attribute already exists in the workspace, as per my third screenshot. It is created in the bookmarked part of the flow just out of my screenshot. I think that this is an error in the workspace that is supplied with FME Flow.  Safe should correct the attribute and replace this in future versions of Flow.
Thanks,
Marc
zoe.forbes
Forum|alt.badge.img+11
  • Jan 14, 2026 7:55 PM UTC
Hi ​@mgg_beca,
This definitely seems like an error with the Utilities/BackupConfiguration.fmw workspace in 2025.2.1 - I’ve reported this to our Development team (reference FMEFLOW-27189).
I’m glad you were able to get the workspace working despite this mistake. Let us know if there’s anything else we can help with!
Thanks,
Zoe
rudy_v
  • Mar 3, 2026 5:56 AM UTC
Hi ​@mgg_beca
I can also report - it has not been fixed, just deployed 2025.2.3
I migrated from 2025.1.2 - and deployed 2025.2.3 - today
Rudy
rudy_v
  • Mar 3, 2026 5:59 AM UTC
Hi ​@skyleratsafe
It would be great if Safe fixes this - and just attasched the fix here, or add it to a download area - to be downloaded.
zoe.forbes
  • Mar 3, 2026 7:08 PM UTC
Hi ​@rudy_v,
