Data Virtualization doesn't accept non-ascii characters in url's
  • Sep 17, 2025 11:57 AM UTC
  • 118 views
lifalin2016
Forum|alt.badge.img+42
I’m experimenting with Data Virtualization, and has encountered a built-in error, it seems.
Whenever I use a variable value with non-ascii characters (ÆØÅ in question), I get a nasty error:
"message": "Error running Data Virtualization Workspace \"DV_LER 2.0_GET_schemas_table_data.fmw\" for API \"ler2\": An error has occurred. Check the logfile above for details"
The value in question is “Afløbsledning”, and the url swagger is using is:
http://localhost:8080/api/ler2/schemas/myschema/table/afl%C3%B8bsledning/data
The error in the Flow log file is:
JSONTemplater_TABLE (XMLTemplaterFactory): The following error occurred near line 1, column 148 of the query:
JSONTemplater_TABLE (XMLTemplaterFactory): "context item": undeclared variable
JSONTemplater_TABLE (XMLTemplaterFactory): An error occurred while executing the 'ROW' query
JSONTemplater_TABLE (XMLTemplaterFactory): The following error occurred near line 4, column 15 of the query:
JSONTemplater_TABLE (XMLTemplaterFactory): An error occurred while executing the process-features function
Translation FAILED with 1 error(s) and 5 warning(s) (0 feature(s) output)
It works just fine if there are no ÆØÅ characters in the value. I’ve tried to add TextEncoders into the workspace without success.
And why is the XMLTemplater mentioned above even involved in the JSONTemplater execution ? Does FME create an XML to convert into JSON ??
What can I do to get around this problem? The value needs to be able to accept ÆØÅ.
Cheers.
Ps! I’ve encountered ÆØÅ problems in the regular REST API as well, so it suggests that it’s a general problem with the API interface. Is it missing proper encoding and decoding of values ?
skyleratsafe
Forum|alt.badge.img+9
Hi Lars,
Thanks for bringing this issue to our attention. We have seen a few issues with non-ASCII characters using Data Virtualization, and some will be fixed in FME 2025.2. I recommend submitting an FME Flow support ticket to help us investigate the issue further. The following information would be helpful.
  • Where did you use the variable value with non-ASCII characters? Could you send us the data virtualization workspace?
  • Could you also send us the API specifications? You could export it in the FME Flow Data Virtualization UI.
  • Could you tell us more about the REST API issue? For example, which endpoint did you use, and what is the configuration?
If you could provide the information above and submit a support ticket, I could take the ticket and help you from there.
Cheers,
Skyler
lifalin2016
  • Sep 24, 2025 7:40 AM UTC
Hi Lars,
Cheers,
Skyler
Thanks Skyler.
I’ve now submitted a ticket with # 58499. Hope it includes all you need to replicate the problem.
Cheers
Lars I.
