zoom to selected feature in workbench?
  • Aug 7, 2014 12:23 PM UTC
  • 10 replies
  • 114 views
Can I not "zoom to selected feature" in the workbench?
  • Aug 7, 2014 12:34 PM UTC
Hi, are you looking for this "Zoom In" tool?
Takashi
gio
Forum|alt.badge.img+15
  • Aug 7, 2014 4:25 PM UTC
lol.
No u can't "ZoomToSelection" ...alas.
I often use a testfilter (also available in Inspector) to select the object, wich then will be full Inspectorscreen.
  • Aug 8, 2014 11:03 AM UTC
If you need to expand shapes geometrically, you can use the Scaler.
gio
  • Aug 8, 2014 1:50 PM UTC
You could use python and arcpy (or whatever its called nowadays) to build mxd. I believe u can set zoom to selection in that way..(afaik)
  • Aug 9, 2014 1:14 AM UTC
Do you perhaps mean the "Zoom To ..." command in ArcMap?
But, there cannot be such a function because Workbench is not a viewer.
I'm missing the zoom to selected function in Data Inspector as well.
Forum|alt.badge.img+63
@mariuskolleck It's the magnifying glass with the i in it
how this button can be activated ?
nampreetatsafe
Forum|alt.badge.img+14
This tool is available when inspecting data using the Visual Preview pane within FME Workbench. It's also available when inspecting data in FME Data Inspector.
