XYZ to Sphere + Add Data
  • May 10, 2019
  • 13 replies
  • 149 views
Looking to create a 3d sphere from the XYZ coordinates in the attached CSV and then add the "Filename" property to each sphere. Can someone help?
Ive tried the Hub3DBufferer, but I cant get the geometry created. Happy with an AutoCAD or similar output.
CSV file attached if anyone can help me
Forum|alt.badge.img+46
  • May 10, 2019
The bufferer will allow you to create a solid 'sphere' (or an approximation of one) from a point
jovitaatsafe
Forum|alt.badge.img+11
Hi @fordy,
Adding onto egomm's answer, these are the parameters that I used to get to get 3D spheres from your points.
I also noticed that you already have an attribute on each feature with _filename but if you're looking to add the CSV's filename, then you can expose fme_basename, and that will add the csv name (27107-xyz) to each feature. You can also concatenate a file name extension if you want to using a StringConcantenator.
If you are writing to a CAD format, try using the Real DWG writer for 3D handling (more info from this article on choosing autocad formats). Here's what it looked like in autocad for me:
  • May 11, 2019
I believe that you can use either the Bufferer (FME 2018+, Buffer Type: Solid) or the 3DBuffere from FME Hub to create spherical solid from 3D points. Try using a VertexCreator to create 3D points from (X, Y, Z) coordinates then applying the Bufferer.
  • May 13, 2019
Thankyou @egomm and @jovitaatsafe it worked very well.
That said, its quite slow. Generating 607 spheres and it took 46 minutes. Is that normal and more importantly, is there anything we can do to reduce the time taken to produce?
Thanks
Chris.
Workspace below (with adding the attributes)
  • May 13, 2019
Thanks
Chris.
Try this.
Create just a single sphere (center point = (0, 0, 0)) with Creator + Bufferer, merge it to every feature unconditionally with the FeatureMerger (Feature Merge Type: Geometry), then offset it by (x, y, z) with the Offsetter.
  • May 13, 2019
Thanks
Chris.
Thanks @takashi I nearly have it, but slightly confused about the feature merger unconditional join, can you help?
  • May 13, 2019
Thanks
Chris.
You can set an identical constant value (e.g. 1) to the Join On parameter for both Requestor and Supplier, in order to merge a single supplier to every requestor.
  • May 13, 2019
Thanks @takashi it worked, but it seems to be as slow to create the 607 spheres.
Is this something I have to just accept?
  • May 13, 2019
I am scaling up to coordinates by 1000. Does this have anything to do with it?
  • May 13, 2019
What settings are you using in the 3dbufferer? Using your sample csv I can create 607 spheres in less than 10 seconds
  • May 13, 2019
Hi @egomm. here are the settings.
  • May 13, 2019
@egomm I think its the RealDWGwriter. When I change to an inspector, it completed in less than 30 seconds
jovitaatsafe
Hi @fordy, would you be able to share your parameters in the 3DBufferer again? It would also be great if you could attach your full logfile as a textfile attachment to get a look at what might be happening to make the translation slow for you. Thanks!
