Writing to Oracle Spatial with apparently valid geometries - but are rejected by Oracle DB
  • Nov 5, 2013 10:46 AM UTC
  • 153 views
Hello all
I have had it  several times, that i cannot write to Oracle Spatial DB apparently correct (at least by GeometryValidator Transformer) geometries. I can write these geometries with other writers (i tested ESRI shapes and ESRI geodatabase). I know that oracle has his own strict geometry validation rules.
Strange enough, the ORA-Error echoed back (ORA 20263) is not a common error found here for example:  http://docs.oracle.com/cd/B14117_01/server.101/b10744/toc.htm
Is there a way to check before the insert, if a geometry is valid (in strict Oracle DB terms). Or is there a parameter within the writer that can catch the Ora-Error, skip the geometry, and continue the process of writing with the other pending geometries?
I'm working with FME Desktop 2013 (20130124), DB is Oracle Spatial 10.2.0.4.0
Yes, you guessed right, english is not my native language.
I appreciate your help.
Bernard
Best answer by fmelizard
Hi Bernard,
Yes, disabling/enabling triggers and constraints can also be a way to avoid these errors.
Itay
fmelizard
Forum|alt.badge.img+22
  • Nov 5, 2013 11:24 AM UTC
Hi Bernard,
I cannot think of a way to do it 'on the fly' as you require (maybe sombody else can ?)
A possible workaround (didnt try it myself and not very elegant I admit) would be to insert the data to oracle (where no geom validation takes place), preform oracle validation on it (sdo_geom.validate_geometry_with_context) and select only the features that pass the validation to write.
Itay
  • Nov 5, 2013 11:50 AM UTC
Hi Itay
Thanks for your reply.
I think I have to go that way. I found out in the meantime, that it is a BEFORE INSERT Trigger, that causes the mentioned ORA-Error. I will disable this trigger.
fmelizard
  • Nov 5, 2013 12:07 PM UTC
Hi Bernard,
Itay
