Writing to existing MS Access database fails with Provider Error (-2146825023)
  • January 14, 2025
  • 19 views
tsol
Participant
I have an exsiting MS Access database. I would like to insert some updated rows to the existing table named tbl_STATIONS, so that the existing rows will be updated. However, it fails with the following error.
Microsoft Access Writer: Failed to write attribute `Id_station' of feature type `tbl_STATIONS'. Provider Error `(-2146825023) Impossible de trouver l'objet dans la collection correspondant au nom ou à la référence ordinale demandé.'
What is the issue here?
AliAtSafe
Forum|alt.badge.img+23
  • January 17, 2025
Hello, ​@tsol!
Thanks for posting your question to the community! Sorry that you’re having an issue with updating your existing MS Access table; here to help out. If you are able to, could you provide a sample workspace and translation log as well as the parameters set on your MS Access writer feature type? It’ll help out to take a closer look at your issue.
Additionally, there was a similar question thread and there are suggestions you can try out which may help.
Looking forward to hearing back from you.
Thank you!
