Writing to a Socrata Dataset with Computed Columns using a template on FME HUB but Dataset not updating on Socrata
  • Mar 27, 2019 7:59 PM UTC
  • 25 views
I am using Socrata_Computed_Columns workbench template to update my data. the workbench ran successfully, but data is not being updated online. I am getting a warning with system caller failing, but not sure what going on. this is a part of my log file where I think the problem is @cdesisto
xiaomengatsafe
Forum|alt.badge.img+11
Thanks for your question @ulylerich! Just wanted to suggest that you also consider posting this question under the comment section of the template in FME Hub: https://hub.safe.com/templates/socrata_computed_columns#comments
This will send an email to the author of the template, cdesisto, who would probably be best able to help you. Cheers!
