Writing Polygon Geom to Spatialite that is on the date line
  • May 25, 2017 5:19 PM UTC
  • 37 views
rhildebrand
Participant
When I write a polygon geometry whose western edge is equivalent to -180.0, but in Spherical Mercator (-20037508.342789244), the longitude value switches signs and becomes positive. I have tried the same process, but writing to a GeoJSON file and no problem occurs.
Is there any value modification occurring when features are written to the Spatialite format?
I can provide a very simple workspace to replicate this if it is needed.
For what it's worth, I believe this is a precision problem.
Simply changing the western longitude from -20037508.342789244 to -20037508.34278924 "solves" the problem. It does however translate to changing the actually geometry because something that originally was equivalent to -180.0 is now -179.99999999999997.
  • May 26, 2017 7:12 AM UTC
You could try the tip outlined in this article and see if it helps:
https://knowledge.safe.com/articles/34013/dateline-problem.html
