Writing Multi line Strings using FME Writer
  • November 29, 2013
  • 156 views
We are using FME to export some graphic geometry objects to microstation format. We are successful in writing simple text elements(single line text) using "igds_type = igds_text". But we have some multi text elements to be exported which we could not write using "igds_type = igds_text". Since this requires to build a complex element with a group of text strings under a text node, we thought we can do it using igds_multi_text type. So, we wrote the following code in VB.
Dim fmeFeatureObj As FMEOFeature
fmeFeatureObj.geometryType = FME_GEOM_POINT
fmeFeatureObj.attribute("igds_type") = "igds_multi_text"
fmeFeatureObj.attribute("igds_text_elements{0}.igds_text_string") = "Line1"
fmeFeatureObj.attribute("igds_text_elements{1}.igds_text_string") = "Line2"
//{comment: Set other attributes like size, font, rotation, justification for the "igds_text_elements{0}" and "igds_text_elements{1}" list elements.}
When I write this feature to the dgn file using FME writer, I cannot see any multi text displayed in the file when i open it in microstation.
Please suggest how we can assign values to the Attribute list in the multi_text node (ex: "igds_text_elements{0}.igds_text_string") in this case to get the desired output.
  • November 29, 2013
I would consider reverse-engineering this: create a test DGN file using MicroStation and insert a multi text attribute on an object.
Then open the DGN using the FME Inspector and see how it is represented by FME.
David
  • December 5, 2013
David,
Thanks for the quick response. That helped me to solve the problem. I missed to set the coordinates for individual text elements. Now I am able to implement that multitext string but i am facing another problem now. I cannot set the index of the attribute lis programatically.
This is working.
Dim count As Long
count=0
fmeFeatureObj.attribute("igds_text_elements{count}.igds_text_string") = "Line1"
This is not working.
Please suggest something.
  • February 7, 2019
Hi, I am having a similar issue. I would like to create a multi line text in a DGN and I have set the AttributeCreator with the following settings. But instead of the text only a point is appearing in the FME Inspector. I am using FME Desktop 2017.1 32 bit.
I am wondering if I am missing something here, or if the issue is related to a text_node (which I don't really understand)..
Thanks!
xiaomengatsafe
Forum|alt.badge.img+3
Thanks!
Note: further discussion on aquamarine's scenario can be followed here: https://knowledge.safe.com/questions/86576/multi-line-text-dgn-microstation-issue.html
