Writing fme_aggregate as polyline to Arcgis online
  • Dec 17, 2025 9:23 AM UTC
  • 265 views
sveinj
Forum|alt.badge.img+3
When using the new ESRI ArcGis Feature Service I get this error when trying to write fme_aggregate geometry to AGOL: Python Exception <FMEException>: FMEException: 1: <class 'fmeobjects.FMEAggregate'> cannot be converted to esriGeometryPolyline
With the old writer I did not have this problem. Is there some solution for this? Deaggregating is not the solution i neede. The multi part geometry is only contaning lines. I have tried GeometryCoercer, but without effect.
nielsgerrits
Forum|alt.badge.img+67
Be aware that there are a lot of possible combinations of aggregates and ESRI only accepts homogenous single level aggregates.
See https://developers.arcgis.com/rest/services-reference/enterprise/geometry-objects/
I suspect this is the issue. An aggregate of multiple geometry types (points and lines) or a aggregate of multiple levels (aggregate in an aggregate).
sveinj
  • Dec 18, 2025 7:47 AM UTC
I use GeometryFilter before Aggregator so the aggregate is only containing lines.
evieatsafe
Forum|alt.badge.img+28
  • Dec 23, 2025 4:41 PM UTC
Hi ​@sveinj to confirm you said this used to work in the previous writer, what version were you using and what version are you using now that gets this error?
I did some quick tests without the error, but I might not use the same version.
Is there anything else about this data other than the simple line aggregates?
sveinj
  • Jan 13, 2026 7:50 AM UTC
Problem solved: Some of the lines in my dataset were aggregates inside aggregates. Also, I changed the layer parameter in FeatureWriter to UPSERT instead of INSERT for writing the aggregates/multilines to AGOL. I'm not sure why.
